You've done the thinking and gotten started. You've made the mistakes, skinned your knuckles, or thought of something brilliant. Hopefully this FAQ or one of the many projects out there has inspired and helped you. Now it's payback time. There's only one price I ask for the efforts I put into this behemoth. Take what you've done, what you've learned, what you'd recommend and avoid, and document it! Someone else is just beginning, and they could use all the help you're able to give. Don't forget what it was like when you were just getting started :)When you're done reading about the ways you can document and share your project, hit the home button
over there on the left to dive on in to the FAQ... Good luck and enjoy!
